shocked
Old 02-27-06, 06:24 AM
shocked
everytime I get out of my car I get shocked...what can I do to stop this from happening
Old 02-27-06, 07:11 AM
I've been dealing with this every winter for the last few years and have not yet found a solution.
Old 02-27-06, 07:22 AM
majakdragon's Avatar
Sounds like you need a seat cover made of cloth. When you slide out, you build up static electricity and you get shocked. Just like sliding your stocking feet across a rug and touching someone. You may want to invest in one of those grounding straps that hang off the rear axle. The pretty one with the lightning bolt painted on it. Good luck.
Old 02-27-06, 07:32 AM
I have cloth seats in my car, apparently that's not enough?
Old 02-27-06, 09:49 AM
The shock hurts because the electricity discharges on a small point on your hand. To reduce the pain, hold on to your key and have the electricity zap the key itself. The large area of your fingers holding the key will dissipate the charge to where you won't feel it.
Old 02-27-06, 04:27 PM
ground strap
In the old days you would see cars with ground straps that would cure this problem.I have looked for them and just can not seem to find them.
They just hang under the car and look like a rubber strap when car is moving they are blown up as not to drag on ground,when car stops they touch the ground.
Also do not wear nylon or syntetic clothes.Now I use my key to touch the metal first sometimes I see a nice fat blue spark.
I will keep looking for the straps and if I find them I will post back.
Old 02-27-06, 04:43 PM
New guy's Avatar
I get shocked everytime I get out during spring, fall and winter. The static strap helps somewhat but not all the time, especially when snow covered the ground. What I did was open the door and hold on to door frame to ground myself first then step out, works 99% of time. Get back in the car is another story thou.
Old 02-27-06, 05:06 PM
thanks
thanks for all the input...I heard before about rubber straps but really was not sure...ieven if I close the door by the window and then open another door or shake someones hand....it's still shocking...I'll look for the straps and maybe static cling spray for seats...thanks again
Old 02-28-06, 07:42 PM
It happens to me only while wearing one particular pair of shoes. Does not happen with my work boots or my hikers.
Try a different pair of shoes, or boots.
Old 03-01-06, 01:39 AM
Talking
move to florida?
