Olds Alero Blinker
Old 02-28-06, 06:30 AM
Question Olds Alero Blinker
I have a 1999 Oldsmobile Alero and am having a problem with my blinkers. Recently they just quit. My hazards still work and I am at a loss as to what the problem is. The fuse in the panel is still good. Can you point me in the right direction?
Thanks
R
Old 02-28-06, 10:16 AM
Check the flasher.
Old 02-28-06, 07:35 PM
Note that the hazard switch IS the flasher for the turn signals. You need to replace the hazard switch, about 90% sure of this. There was a recall on the N body vehicles, which are the Alero and the Grand Am. Try pushing hard a few times on the hazard switch and then try the turn signals to see if they work.
I can double check at work, but I'm pretty sure this is the problem.
Old 03-01-06, 06:54 AM
Cool, thanks. I will give it a shot. If that doesn't work, I will replace the assembly.
R
Old 03-01-06, 01:11 PM
Alright, I'm 100% positive on this one. I have the documentation if you want to see it or need it.
If so, pm me your email address.
