Ranger died
Old 02-28-06, 03:01 PM
awesomedell's Avatar
Question Ranger died
Got a 95 ford ranger that had the ignition switch fail yesterday. While trying to switch it off, tumblers spun free. Would only try to start again. Pulled ignition/PCM fuse to get her to die. Installed new switch but can't get her to start. Fuel pump isn't activating when key is turned on? Any ideas?
Old 02-28-06, 05:43 PM
ignition/PCM fuse Did you put them back.
Old 02-28-06, 07:19 PM
ranger died
yep and they are good fuses
Old 02-28-06, 07:20 PM
ranger died
Yep and they are good fuses. Are there any reset switches?
Old 02-28-06, 10:14 PM
Ford uses a relay aswell as a fuel pump cut off switch .Not sure where cut off switch is on PU.But relay will be in engine compartment in fuse block.But I think it has more to do with the new ignition switch hook up.
Trackbacks are On
Pingbacks are On
Refbacks are On
