92 Ford Aerostar headlights shut off
Old 03-01-06, 06:10 PM
For some reason the headlights on my van suddenly shut off while I am driving. Then they will come back on. Sometimes they will be out for a few seconds and sometimes a few minutes. Then all of a sudden they will stay on for a while before they shut off again. Could this be the dimmer switch? I have no idea where to locate it on this van.
Any ideas?
Old 03-02-06, 04:45 AM
possibly it is probably the dimmer/multi function switch or the main light switch multi function switch is probably in the column if you dim the lights using the turn signal handle, while it could be a loose ground inspection of both switches will probably show some burned contacts at the swicth connector and possibly a melted connector wich could cause your lights to go on and off.
