wat could be the problem with my 1988 firebird
Old 03-04-06, 11:36 PM
i have a 1988 firebird with the 305 tbi engine and it will not start it ran fine up untill about 2 weeks ago i am getting the correct fuel pressure and am getting spark to the coil i have since changed the cap rotor wires and plugs wat eles could casue this problem ne help whould be greatly apprectiated thank you
Old 03-05-06, 02:07 AM
ignition module
Does it have a ignition module?If so that will kill a car and it will not start.It is in the distributer on older GM cars.
Old 03-05-06, 09:24 AM
is that the the module with 2 bolts that hold in and 2 plugs on it, and it is mounted under the rotor thank you
Old 03-05-06, 10:34 AM
Check for spark at the plugs and fuel in the throttle body (you can see it squirting out the big injectors)
Old 03-05-06, 12:47 PM
O
Yes it is the the module with 2 bolts that hold in and 2 plugs on it, and it is mounted under the rotor and also change magnitic pickup assm.
Old 03-05-06, 01:58 PM
thats the module
Yep like 442 said that is the module that goes out and leves you dead on the road.It has happened to me in a old nova easy fix.
