Transmission problems
Old 03-05-06, 03:54 PM
B
I need to know what can cause the transmission to not go into reverse and how to fix it? It is on a 1987 Cutlass Supreme Oldsmobile, automatic transmission, the transmission is a Hydromatic with a 3.8 engine. How can I repair it? I do have another transmission that I might be able to put in the car the only difference is that the original transmission has wiring and the other one I have looks the same but does not have the wiring can this still work in the car. Need help as soon as possible.
Old 03-05-06, 05:23 PM
LouBazooka's Avatar
May not be the same kind of tranny,most likely you will need a transmission overhaul, not a quick fix.
