Losing anti-freeze somewhere, help!
Old 03-06-06, 05:39 PM
I have a 1999 Pontiac Grand Am. Every couple of days I have to put in anti-freeze. I park it and can't see any spots on the ground. The radiator looks good, all the radiator hoses are dry, even the ones going into the heater. When I drive it to work, I can see smoke coming out from the grill, but nothing is dripping under the car, that I can see. It seem to be wet behind the pullies and the long pully belt. Is there something behind these pullies, a by-pass hose or something? I can let the car idle and see nothing. It seems like I lose it while I'm driving and it's under high pressure. Any ideas?
Old 03-06-06, 05:43 PM
what engine do you have.
Old 03-06-06, 06:08 PM
Check weep hole in under side of water pump. Check for coolant in oil (Head gasket) rad cap.
Old 03-06-06, 06:50 PM
not to sure of the motor size, it's my son's car. I do know its a 6 cyl. No water in the oil, seems to spray out when driving the car.
Old 03-06-06, 07:27 PM
v8driver's Avatar
3.1 maybe? check around the intake as well, after it cools, you may see a wet ( depending on what color antifreeze you use ) liquid seeping out, it'll smell like it as well.
Old 03-07-06, 06:33 AM
Park it on a clean piece of cardboard immediately after driving it and see if there is any coolant on the cardboard after sitting overnight. Also, look at the exhaust when it's running, it will be white if coolant is leaking into the combustion chambers.
Old 03-07-06, 04:17 PM
3.1/3.4 LIM gasket, known problem with these engines, GM is on their 3rd type of gasket now, a little better than the others, but still not a "fix". You can do it yourself, all day job, but not unmanagable.
Old 03-07-06, 06:15 PM
v8driver's Avatar
http://www.theautochannel.com/news/2...14/252583.html
Old 03-07-06, 06:34 PM
Check bypass hose at front of engine corner of passenger side.
