Need help on Timing Belt Replacement (for Pathfinder 97)
Old 03-07-06, 07:59 AM
I tried to replace timing belt for my pathfinder 97 (XE V6 3.3L 4wd) last Sunday.
I had successfully removed radiator, fan clutch, radiator hoses, all drive belts. But
I can not figure out where is the breather hose and breather pipe, which according to
the Haynes manual, need to be removed before i can remove the timing belt cover.
But it didn't tell me the detail.
So I kind of chickened out and replaced all drive belts and installed everything back because
I need this car next day.
Can somebody give me a hint on what are is breather hose, what is breather pipe, what
do these pipe/hose do? How to remove it?
Thanks a lot
Old 03-07-06, 09:41 AM
New guy's Avatar
That's the pipe in front and on top of timing belt cover, connecting from one valve cover to other.
Can you remove a crankshaft pulley bolt?. Try to remove/loose it first before going in too deep.
Old 03-07-06, 12:23 PM
Old 03-07-06, 01:51 PM
New guy/Our442
Thanks a lot for your help!
Could you please tell me what does breather pipe/hose do? My guess is to expel exhaust out?
Also, I have taken some pictures by using my digital camera after I removed all the drivebelts,
could you please point on the picture where is that breather hose/pipe. Can someone tell me how
to post a picture in this forum?
Old 03-07-06, 05:13 PM
Cut and paste to you thread.
Old 03-07-06, 08:47 PM
what do you mean?
"cut and past to your thread"?
Old 03-07-06, 09:05 PM
Right click on pic. and then click on copy and then click on paste when you are on this web page.
Old 03-08-06, 07:09 AM
Old 03-08-06, 09:29 AM
New guy's Avatar
On your very last pic (img_0578.jpg) .
There's a hose in front of the distributor that connected from air duct(air cleaner housing) to the pipe(breather pipe), the breather pipe/hose also runs from one valve cover to other, you will need to remove that pipe/hose first prior to remove the timing cover.
Again, I'd try to remove/loose the crank pulley bolt first before going too far, if you have a good 1/2" air impact wrench and air compressor, disregard this, otherwise you may stuck in the middle of the job.
Old 03-08-06, 11:02 AM
Like new guy said try to remove/loose the crank pulley bolt first before going too far,Sometimes a rachet with pipe over the end will make help to take off nut.
Old 03-08-06, 01:00 PM
Thanks guys!
Advanced Auto Parts have a tool for rent called "harmonic puller" for 89 bucks. If I
return it within 45 days, they will give full money refund.
They claim this tool is perfect for almost all kinds of crankshaft pulley. But I don't know
if it will help to remove the nut. I will check with those guys tomorrow.
Seems you all recommend to remove the crankshaft nut first. But according to the manual,
I need to remove spark plug and set TDC before removing crankshaft nut.
How do you think?
Besides, could you please kindly tell me:
1. what is breather pipe/hose, what do they do?
2. On the picture I posted, please pin point where they are.
Or should I retake picture because the current one does not have a whole set?
Thanks
Old 03-08-06, 01:48 PM
Send a better pic of breather pipe/hose,
Trackbacks are On
Pingbacks are On
Refbacks are On
