bad noise from front end
Old 03-07-06, 06:10 PM
my 93 grand am (2.3L SOHC, auto, fwd, 24k original miles) has been making a bad noise when going over any large bump or dip or anything that would cause the front end to move up and down a significant amount. It does not do this under normal potholes or anything, but when i go over a crossroad, or one of the speed hills at school (little hills instead of bumps, about 7 feet long and 6 in high) The noise is sounds like it is coming from the front passenger wheel/suspension area and sounds like something stuck breaking loose that does not want move. sort of sounds/feels like the same type of sound made when you break a large rusty bolt loose. Ive tried to bounce the front passenger side of the car when parked, but it does not make the noise, or keep bouncing after I stopped, like a bad shock/strut might. Any ideas?
Thanks
Old 03-07-06, 06:28 PM
Check front strut spring as i have have had to change a lot of them in the grand ams. Springs brake easy on these cars.
Old 03-07-06, 06:46 PM
Sgt D USMC's Avatar
Concur with our442
I agree with our442, I had a simular problem with a car I owned in the past, I changed the struts and the problem went away. If you do it yourself to save money, make sure you take the car and get an alignment.
John
Old 03-08-06, 05:33 AM
you should probably take it to a front end shop to have the front end checked out they may be able to tell you what the problem is while there is a good chance it is strut or mount related atleast you will know for sure and whether the vehicle is safe to drive or not.
Trackbacks are On
Pingbacks are On
Refbacks are On
