1995 Dodge Ram 5.2 Engine ?
Old 03-10-06, 04:54 AM
Bernard_01's Avatar
This vehicles has been mine since new. It has been terrific. All routine maintenance always performed. 109K at present. This week it stalled while in line at a bank. Would not re-start. AAA towed it home. Now, it will start for 10 seconds , blow tons of pure white smoke (which it never did before) and then die again. After about 4 hours, it will start again for another 10 seconds, blow all the white smoke and die again. I have excellent fuel pressure. plenty of spark. No overheating at all. No service engine light came on. Am I looking at a possible head gasket failure here?
-THANKS.
Old 03-10-06, 06:32 AM
Dose the oil look milky. Sounds like head gaskit. (This is juist my opinion.)
Old 04-15-06, 06:37 PM
the dodge 3.9/ 5.2/ 5.9s intakes have a belly pan and the gaskets go bad i would suggest pulling the intake getting a new intake gasket and a new belly pan gasket , dodge did away with giving you new bolts for the intake because they hardly ever stretch, but i would get the belly pan bolts also get a can of carb cleaner and clean the pan lots of times the get a build up. good luck . paul ([email protected])
ps.. make sure you change the oil and filter
