Need Help with a/c
Old 03-12-06, 08:29 PM
Question Need Help with a/c
I have a 2002 Hyundai Santa Fe. The a/c started blowing warm air, so I had a can of 134a coolant put in and it worked fine. In a matter of 2 weeks it started blowing warm again. I also noticed that the compressor is not turning on when the a/c is turned on. Please help, what can it be?
Old 03-12-06, 08:41 PM
You need to do a leak test. Compressor will not turn on when the a/c coolant is low. May be a o-ring or hole in a line. (This is juist my opinion.)
Old 03-13-06, 05:52 AM
If you still have some pressure, one quick way to check for leaks is to squirt soapy water on all suspect areas. If you get bubbles, you've found the problem.
