How to remove lens?
Old 03-13-06, 09:44 AM
B
How to remove lens?
Hi:
I have a 2001 Nissan Pathfinder. I am trying to remove the rear lens on the driver side to replace a bulb. I lifted the hatch, removed the 2 screws from the lens. The lens is loose and I can pull the side with the screw holes away from the vehicle BUT the portion of the lens that wraps to the drivers side of the vehicle will not pull away.
What am I missing...Thank you very much.
Bob
Old 03-13-06, 02:19 PM
New guy's Avatar
You are not missing anything, the other side was holding by two pins, just hold the lens straight and level then give it a pull EVENLY on both side, it should come out.
