A/C compressor stop when idling
Old 03-15-06, 05:25 PM
R
Question A/C compressor stop when idling
1999 Saturn SL2 4 cylinder. When the car is idling the compressor stop running. As soon as car starts running again A/C runs great. What could cause this?
Old 03-15-06, 11:47 PM
O
How do you know it stops running.Some times engine runs to slow for compressor to keep ac cool at idle.I have seen this before with 4 cyl. cars in the past.Not much you can do about it. Car speed would have to be set faster at idle and most new cars can't be do to ECM. (This is juist my opinion.)
Old 03-16-06, 03:33 AM
B
suggest taking to a shop to have the a/c system checked while normally it will cool a little better going down the road It should still have decent performance even at idle a cooling fan not working could cause poor performance at idle and may even cause the a/c compressor to kick off due to excessive high pressure not to mention be hard on the a/c components, or it could be as simple as a little low on freon it will only get more noticable as the temp get warmer outside during the summer.
Old 03-16-06, 08:49 AM
R
A/C compressor stops when idiling
I can see the compressor stop turning after a while when car is idiling.
Old 03-16-06, 08:51 AM
R
I think I will take to shop, it started last fall, before that no problem when car was idiling. Did not do anything to it because it was getting cold, now it's that time of year again Thanks
Old 03-16-06, 11:19 AM
O
When was last time you had it charged.
