95 Blazer Start Problem
Old 03-17-06, 05:35 AM
Recently in my 95 Blazer the ball-bearings on my alternator started to go.. I caught it early before it actually failed, I purchased a alternator from a junk yard and changed it, very simple I changed an alternator before and had no problems. When i was done connecting it i tried to start the car... nothing... it would crank but not start....
I assumed that it was a bad alternator from the junk yard and placed the old one back in the truck just to be sure bacuse it would still start the car... when i was done putting the old one in i went to start it expecting that it would be fine... but nothing ... it would crank but not start...
At this point i have asked many people and cannot find a problem.. i do not have the money to bring it to a repair shop.. and i have hit a dead end... the battery is fine... all the wires were connected back correctly and the belt is on and tight....
Any help would be greatly appriciated! Thank You!!
Old 03-17-06, 07:44 AM
1Check to see if fuel pump is running when key is first turned on,Should run for 3-4 seconds.2 Pull a spark plug wire off and see if you ar getting spark when cranking engine. (This is just my opinion.)
Old 03-17-06, 05:40 PM
did you disconnect the battery? if not you may have blowed a fuse changing the alt.
Old 03-18-06, 04:53 AM
p.s. i guess i forgot to write that part... i disconected the battery during installation and it has enough juice (its a good battery) its still reading at 12 volts.
Ok.. this is now where i stand... i checked the spark plug... (ty our442) it was sparking which certinally narrowed down the problem a bit. I then started thinking about it and went out and bought some ether... while spraying the ether into the air intake i atemptd to start the vehicle (there is 2 people working on this) IT STARTED!! (recharging the battery as well, knowing that it is not a bad alternator) but as soon as we stoped the ether the truck stalled... so should i assume that it is a fuel problem? what type?
Thank You for Your Comments and Help!
Old 03-18-06, 09:54 AM
Check fuel pump fuse and relay in engine bay and check fuel filter if not that then check fuel pump.
