gaz problems
Old 03-18-06, 02:22 PM
N
Angry gaz problems
Hi Can You Help? When I Gave Gaz To My Car It Does Not Move Until I Floor It Or Gave It On And Off Gaz, Then It Might Work. And On The Road It Does The Same Have To Pump The Gaz, Its A 1989 Jetta Gaz, And I Change The Air Filter,it Still Didn't Help.
Thank U Nick
HI THANKS FOR THE ANSWERS. I HAVE ONE MORE WHERE IS THE GAS FILTER ON MY JETTE, BY THE WAY I BOUGHT IT A YEAR AGO AND NEVER DID ANY REPAIR ON IT. ++ IF THERE IS WATER IN THE GAS TANK HOW CAN I GET IT OUT?
THANKS ALOT GUY'S OR LADYS
Old 03-18-06, 03:40 PM
B
it may have one of several problems, bad ecm, injectors,fuel filter, plugs, battery, altenator,bad gas,
gas cable loose or about to let go, throttle control, the list can go on. tell us what type of maintenace has this car recieved in the past? we may be able to pinpoint the problem. ( by the way it's gas, not gaz as the fuel source).
Old 03-18-06, 05:35 PM
O
Have you changed the gas filter. Plus you may have water in gas. (This is just my opinion.)
