need help finding oil press. sending unit
Old 03-23-06, 03:50 PM
R
Smile need help finding oil press. sending unit
i have an old 1991 lincoln continental with a 3.8 v6,all electronic dash.the car runs great but once in a while the oil press will cut up and set off a chime,this always happens running down the road not idling.could anyone tell me the location of this sending unit.it has 142k and uses no oil,thanks.
Old 03-23-06, 03:59 PM
Bernard_01's Avatar
Hi and welcome to the forums....
it sounds like a "lazy oil pump?"..... the pump is located inside the oil pan where you drain your oil. you have to remove the pan, gasket ....then you will see the pump.
Hope this helps.
Old 03-23-06, 04:55 PM
R
Smile 91 lincoln
thanks for the reply.could you give me the location of the oil pressure sending unit?thanks again
