Oil spews from dipstick tube...?
Old 03-24-06, 02:50 PM
My son's Caprice Classic spews oil from the dipstick tube while engine is running. What is/are the cause(s)? Would appreciate any advice. Thanks
Old 03-24-06, 03:15 PM
well firstmake sure oil level is ok and not overfull.
if oil level is fine it is usually caused by blowby from the engine, worn piston rings which causes pressure to build up in the crankase it may be time for a rebuild or a new car.
Old 03-24-06, 03:33 PM
Thanks.
Your prompt reply is very much appreciated (even though it was possibly my most feared result). Thanks again and we wish the best for you and yours. Glennj
Old 03-24-06, 04:06 PM
I'd also check PCV valve, and filter if applicable. When they're plugged, the engine has to vent somewhere.
Old 03-24-06, 04:08 PM
Check the PCV system for proper operation also.
Old 03-24-06, 04:10 PM
Also check and make sure that the dip stick is fully inserted. My jeep has about 40k on the engine rebuild but twice I have failed to fully insert the dip stick resulting in an oily mess
Old 03-24-06, 07:08 PM
If it is a pre-fuel injection, it could be a bad fuel pump diaphram leaking fuel into the crank case. Does it smell like gas?
Old 03-25-06, 10:06 AM
Good point, gas mixed in with the oil will overfill the crankcase with diluted oil - not good for the motor
