Oil pressure reading problem
Old 03-30-06, 09:18 AM
bap
bap is offline
I have a 2000 Lesabre with DIC readout. Oil pressure says "normal" but just started reading 129psi and does not vary with acceleration/deceleration of vehicle. Oil level is fine. Is this a sender unit problem?
Old 03-30-06, 05:55 PM
Yes, we have seen a number of these in the shop with the exact readout. You need to replace the oil pressure sender.
Old 04-06-06, 06:14 AM
bap
bap is offline
where's the oil pressure sending unit?
thanks for the tip. Is the oil pressure sending unit on the oil pan? There is a sensor on the front of the oil pan but I don't know if that is the oil level or oil pressure sensor.
Old 04-06-06, 07:34 AM
Its located on the oil filter adapter. I'd post a pic, but don't know the F how on this forum .
