Still Havin A/C problems
Old 04-01-06, 02:48 PM
My 2002 Hyundai Santa Fe still having a/c problems. A leak test was done, and no leaks detected. Refrigant level is fine. The compressor is not coming on when a/c is turned on. What else could it be?
Old 04-07-06, 11:00 AM
Thumbs up A/C problems
It's a real shame that unpopular vehicles like Hyundais and Geos don't attract a lot of help.
First, see if you can observe the magnetic clutch engaging when someone else turns on the A/C.
If it doesn't engage it sounds like either your compressor magnetic cluch is shot, has a bad ground, or you are not getting voltage to it. My first guess is the electrical circuitry controlling the clutch. You need a voltmeter and a wiring diagram for your make/model.
