95 blazer heat control
Old 04-11-06, 06:37 PM
Norm's Avatar
Unhappy 95 blazer heat control
Hello i have a 95 s 10 blazer 4x4 4 dr with air the heat control is stuck no matter where i set it still blows hot air . Have changed the heat switch in dash still no help when i set it to air or vent just blows hot anyone have a idea what to look at next ?
Old 07-09-06, 10:57 PM
Norm's Avatar
Re : heat problem cure
Seems i have found out the problem it was a motor in the dash by heater core which has a electrontic board as well , also worm gear in it controls the damper door part was $ 69.00 dollars cost to install was $ 600. the dash has to be taken out completely big job hope none you other people have to do this .
Old 07-10-06, 05:37 AM
davzack's Avatar
It's actually not as bad as the labor in the book calls for...my guys can do it in about 2 1/2 hours. You might call and shop that repair around to see if someone can do that repair cheaper.
Old 07-12-06, 09:43 PM
Norm's Avatar
Well I'm from British Columbia seems the rate is about same no matter where one goes. Everyone says the heater core is to be pulled with it there for 5 hr job give or take with a hr rate of 79.00 per hr in most all shops the odd one at 68.00 hr
Trackbacks are On
Pingbacks are On
Refbacks are On
