power windows
Old 04-14-06, 08:57 AM
T
New Member
power windows
Ihave a 99 grand dodge caravan and was having problems with the passenger side power window...I replaced the window motor and it worked fine for a few days....then it started working intermittenly...were do i go from here?...could i have recieved a bad motor or is there something else i can trouble shoot....thanks for the help..
Old 04-15-06, 05:05 PM
P
Have you checked to make sure it's not the switch instead of the motor?
Pecos
Old 04-15-06, 10:25 PM
B
if you hear the motor when the switch is pressed just no window movement would suspect the regulator.
Old 04-16-06, 08:18 AM
T
New Member
I do not hear the motor at all unless the window opererates.....is there a relay or anything else to check...thanks
Old 04-16-06, 08:19 AM
T
New Member
I do not hear the motor at all unless the window opererates.....is there a relay or anything else to check...Iget the same response from both the driver and passenger side.....thanks
Old 04-16-06, 03:54 PM
B
check the switch and if they dont never work might check the fuses but if they work part of the time probably a switch or broken or bare wire at wiring near the door hinge.
