rusty bumper - 97 dodge
Old 04-17-06, 12:52 PM
Hi,
I've got a 97 Dodge Ram with a back bumper that's got a good amount of surface rust on it. Apparently these particular vehicles are known to have that problem.
So, a buddy of mine has a grinder, what all is involved in stripping that and repainting it? doesn't need to be a perfect job it's a paid for work truck with plenty of scratches otherwise. My friend is a mechanic who hasn't done much body work but is otherwise pretty handy.
Thanks for your input,
Scott
Old 04-17-06, 01:07 PM
G
First remove the bumper, if at all possible. Then use a commercial paint stripper to remove all of the old paint. Next, sand or grind out all rust.
Apply a conversion coating of phosphoric acid - available at most large auto parts stores. This locks in any invisible rust and prepares the metal for finishing. Follow up with a primer and then two coats of finish. Your bumper should outlast the rest of the truck.
Old 04-17-06, 01:12 PM
Sounds simple enough. Thank you!
Old 04-18-06, 05:32 AM
I'd use Eastwood Co. Rust Encapsulator
http://www.eastwoodco.com/jump.jsp?i...ORY&itemID=374
I'd still remove as much rust as possible before applying it
