bad rear axle bearing
Old 04-19-06, 07:58 AM
D
i own a 2000 chevy silverado with 100,000 miles i just changed
the rear brake pads and i noticed play on the drivers side rear axle,
what coul be causing this bad axle bearings or somthing in the
differincial gear gone bad,what can i check to determine the
problem.
Old 04-19-06, 08:51 AM
C
Is the slack when its moved up and down or in and out?
Old 04-19-06, 02:32 PM
D
rear axle slack
up and down
Old 04-19-06, 03:17 PM
C
First check the oil level. Have you hauled anything heavy on any long distance trips? if the oil is low or driven straight while overloaded the bearing will get overloaded/hot and wear. If the oil gets even a little low it will not run out the axle housings to the bearing.
