What Would You Use?
What Would You Use?
what would you use to plug the heater outlet on my rad in my 1990 chevy astro, i tried a bolt but the pressure blows it out after a couple of days.
Originally Posted by zzzz1486
is this just a seasonal thing? or are you replacing the radator or something? if you want to take care of it permanitly, you can solder it.
permanitly, can't solder it because the rad is hard plastic
Originally Posted by slickshift
You can't run a bypass hose from outlet to inlet? Just bypass the heater core?
Try JB Weld with a bolt
I would try another bolt but this time put some JB Weld on the threads of the bolt right before you put it on and let it dry overnight, that bolt wont never come off, believe me I JB Welded a fly wheel on a garbage truck and I havent had the slighest problem with it yet, that stuff will hold anything.
I'll Try That Thanks.
