1997 Plymouth Grand Voyager passenger side mirror
Old 04-20-06, 01:11 PM
W
I need to replace the passenger side mirror on my 1997 Plymouth Grand Voyager. How is this done?
Old 04-20-06, 01:41 PM
the_tow_guy's Avatar
Should be a trim piece on the inside that either pops off or is held on by a screw. Once you remove that you should find the screws that actually hold the mirror on to the door. Fairly easy job. If it's electric you will need to gently pull the wires out to disconnect the connector. In some cases you might have to remove the inner door panel to disconnect.
Old 04-26-06, 06:52 AM
W
Outside mirror on Plymouth Voyager
Thank you for your information. I will give it a try.
