Gas Gauge
Old 04-22-06, 02:08 PM
A
Gas Gauge
After filling my 1990 Chev Pickup the gauge works to about a quarter tank and then stays there. Any ideas will be appreciated.
Thanks.
Old 04-22-06, 04:52 PM
Assuming that your sending unit is similiar to the old fords, I would guess that either the rod [on the sending unit] has gotten bent or [more likely] that the float is bad not letting the sending unit arm rise to the top. There is a slight possibility that you have a bad conection somewhere not letting the gauge get the full current.
Old 04-22-06, 05:39 PM
A
[QUOTE=marksr]Assuming that your sending unit is similiar to the old fords, I would guess that either the rod [on the sending unit] has gotten bent or [more likely] that the float is bad not letting the sending unit arm rise to the top. There is a slight possibility that you have a bad conection somewhere not letting the gauge get the full current.[/QUOTE
Thanks. It is probably the float - I was hoping it might be something else
