Tacoma trailer wiring ?'s
I have a 2002 4X4 D-cab tacoma, put a "tailight converter" on it for the boat trailer set-up (to cover the amber turn signal issue), and now i'm noticing that i only get 9v out of my left turn signal, but 11v on the right, all the trailer lights work fine, except the left turn with only 9v. I have a solid ground everywhere, running lts are fine, but why would i only be getting 9v out of the left signal??? I tested up under the bed where i installed the kit, and still only 9v. Any ideas? thanks alot
if everything works fine why do you worry about it ?
switch to decaf
The left signal on the trailer DOES NOT work, because it only is putting out 9v, not enough to operate the turn signal. I tried re-wiring to make the right light operate it, and it's fine, so the 9v is the problem, wondered if anyone has seen this
