1993 Saturn SL2 CruiseControl
Old 04-24-06, 09:46 AM
93 Saturn SL2 Cruise Control and Odometer both quit at the same time. Are these two connected/related to eachother? Where would be a good place to start?
Thanks for any and all help,
Byam
Old 04-24-06, 01:48 PM
do you have a check engine light on might have codes checked the speed control and speedometer often both use the same readings from the vehicle speed sensor.
is just the odometer not working or is the speedometer not working also?
Old 04-24-06, 01:52 PM
No check engine light. The speedometer works fine, it's just the odometer (besides the cruise) that doesn't.
Byam
Old 04-24-06, 01:59 PM
have you checked all the fuses wouldnt expect the problem to be related to each other.
Old 04-24-06, 03:21 PM
ksion15
93-94 year model saturn odometers failing is a common thing. you won't find many of those year model cars with the odometer working. a small gear strips inside of the instrument cluster. you'd have to replace the cluster, or find someone capable of repairing it. as far as the cruise goes, it could be several things. switches, wiring, fuse, or the module itself.
