need a mechanic for this one
Old 04-25-06, 02:27 PM
1990 chevy s10--2wd pickup--Im having some vibration/shuddering in driveline on 2.5 l with 176k on it.. 5 spd manual- Clutch grabs fine- just replaced plugs, wires, cap rotor, fuel filter, air filter- occurs at mid-upper rpm with engine under load- most noticeable in 3rd gear and lower end of 4th gear-- feels similar to being in too high of a gear for current speed -- any similar problems or clues as to how to diagnose this?
Old 04-25-06, 03:04 PM
shot in the dark
Just a thought but what condition are your engine and transmission mounts in? Do an inspection of them use a strong light and mirror and a lift if you can.
Old 04-25-06, 04:08 PM
Retarded timing has that same feel.
I don't know about anyone else, but a timing light is the only way I can get timing right.
Old 04-25-06, 04:38 PM
aja8888's Avatar
neighbor has same problem.
Neighbor has same truck, lots of miles. Replaced universal joints but the mechanic did a bad job by pressing them out. Then it really shook. He had to get a rebuilt and balance driveshaft section.
Hope this helps.
Tony
Old 05-02-06, 04:43 PM
s10 shakes
Turns out ujoints are wasted-- will be replacing this weekend -- Thanks for the advice!
Old 05-02-06, 04:46 PM
good deal
Good deal thanks for the update.
