A/C problem, 1997 Cougar 4.6L.
Old 04-25-06, 05:35 PM
aja8888's Avatar
Exclamation A/C problem, 1997 Cougar 4.6L.
I have a 97 Cougar 4.6 liter, 89 K miles with an A/C problem. The A/C compressor appears to be cycling on and off about every 4 to six seconds. With the hood open and the A/C on, the cooling fan is running and I can hear the clutch engaging then disengaging. On the low pressure side I have 45 PSI as I checked with a gauge.
My Ford repair CD suggests the A/C cycling switch as a possible cause.
Any thoughts here?
Thanks,
Tony
Old 04-25-06, 08:07 PM
DNT1
cycling switch sounds like it is cycling as it should, most likely you have a leak and the system is low of refrigerant. To properly diagnose you need to use a set of manifold guages so both low and high side pressures can be taken. Anything less is a recipe for disaster. If you are using one of the death kits toss it in the trash and go invest in some real tools before you damage the system.
Old 04-25-06, 10:58 PM
aja8888's Avatar
Agreed.
I will take it to a shop. Thanks!
Tony
