95 Chev Blazer not turning over
Old 04-27-06, 02:38 PM
dave85
Hey guys how's it going....I have a 95 chev blazer thats been running great......Yesterday i get home from work, unload my lawn equ. and take the trailer off the truck, and the truck wont start..........The damn thing just quit, it wont turn over but its got full battery power....I have noticed a couple of times when going to crank it that it it would kind of drown out when you turn the key but after trying again it would start up....any help?
Old 04-27-06, 04:23 PM
you sure the battery is good how about the cables might take them off and check for corrosion usually just the positive will be corroded and make sure they are tight do you have dash lights and everything else seem to work may have a starter going bad could try tapping on it with a hammer then attempt to start it.
Old 04-28-06, 09:38 AM
dave85
Hey man ive tried checking for corrosion, there was very little....cables are tight everything seems to be working fine and the battery has got power.....ill try tapping on the starter....is there any other ideas, im thinking alternator but i dont know how to check to see if thats the problem thanks fellas take care
Old 04-30-06, 09:25 AM
dave85
hey guys.........Maybe this can help out with the problem a litte more......i tried jumping it over from the terminals on the starter, nothing....it made no attempt to turn over or start, does this mean starter or solenoid or what.........Im far from a mechanic so any help is greatly appreciated
Old 05-01-06, 07:10 AM
dave85
Alright guys i havent been receiving much help, maybe because of the lack of info i provided.....yesterday i jumped my truck off from the starter( the 2 posts on the starter) and all i got was a spinning noise....it sounded to me like the teeth on the starter were either broke or not catching on something, it was just spinning.........now my ? is i know that means my starter needs replacing, but why am i not getting antything when i turn the key?
Trackbacks are On
Pingbacks are On
Refbacks are On
