1995 Camry door will not open
Old 04-27-06, 06:07 PM
The front door of my 1995 Camry cannot be opened from the inside or outside. The interior and exterior handles appear to have broken links or clips that are on the links.
I have removed the bezel and can see that the white clip on the link attached to the interior handle has broken. I have also removed two pins on one end of the door and two screws on the armrest. However, I cannot get to the other two screws that are covered with small plugs, they are behind the instrument panel. The door trim pad is loose but still attached by those two screws. When I stand outside the car and look down inside the door while pressing the glass back and turning the key in the outside lock I can see a small green or yellow clip, one end is attached to a link that moves up and down it appears to be broken and the other end is stuck in the side of the door. I really need to get this door open so I can removed the door trim pad. Any ideas.
Thanks
Old 08-14-06, 09:43 AM
1994 Camry door will not open
I have exactly the same problem on a 1994 camry.
Sorry I don't have the answer.
