What Would You Use?
Old 04-28-06, 02:16 PM
chevyastro4x4's Avatar
Question What Would You Use?
what would you use to plug the heater outlet on my rad in my 1990 chevy astro, i tried a bolt but the pressure blows it out after a couple of days.
Old 04-28-06, 05:31 PM
Z
is this just a seasonal thing? or are you replacing the radator or something? if you want to take care of it permanitly, you can solder it.
Old 04-28-06, 05:44 PM
You can't run a bypass hose from outlet to inlet? Just bypass the heater core?
Old 04-28-06, 09:12 PM
permanitly, can't solder it because the rad is hard plastic
Old 04-28-06, 09:16 PM
thats the problem they dont make a rad for my van that doesnt have just oil cooler and trans cooler, they only make one with both of those and a ext heater which mine has but mine connects to the intake manifold.
Old 04-30-06, 03:12 PM
D
Try JB Weld with a bolt
I would try another bolt but this time put some JB Weld on the threads of the bolt right before you put it on and let it dry overnight, that bolt wont never come off, believe me I JB Welded a fly wheel on a garbage truck and I havent had the slighest problem with it yet, that stuff will hold anything.
Old 04-30-06, 03:19 PM
I'll Try That Thanks.
Old 04-30-06, 03:28 PM
D
no problem, good luck.
