95 Mercury Marquis - No hazard flashers.
Old 04-30-06, 02:36 PM
New Member
As the title says the hazard flashers on a 95 Merc Marquis don't work.
The turn signals themselves work, the brake lights work so all bulbs are good.
All fuses have been checked both in the fuse panel under the hood and the one under the dash.
Right now the main problem is I can't find the darned hazard warning flasher. The car was bought used in great shape with low miles just no owners manual and I can't find the darned hazard flasher to do any troubleshooting at that point. I'm sure the hazard warning switch is working because with the hazard switch off the stoplights work fine. With the hazard switch in the on position there are no stopligts nor are there any hazard flashers.
Any help will be appreciated.
Old 04-30-06, 03:57 PM
W
Flashers should be either in the fuse box or tied on or near the steering column..............but I will tell ya..........The #1 problem when it comes to Fords is the infamous "Multi Function Switch"
Old 05-01-06, 11:05 AM
New Member
Reply yo MrWrench
Thanks for your comeback my friend.
The hazard flasher isn't in the fuse box, there's a place in the plastic for a flasher, but there are no terminals which leads me fo think the flasher is located somewhere else.
There is some sheilding/covering or whatever preventing access to the under dash area or steeing column and I can't figure out how to get that off.
Pardon my ignorance but, what is the "multi function switch"? Is that the turn signal switch itself? Does it require the removal of the air bag equipped steering wheel?
Again thank you for your prompt reply.
Old 05-09-06, 01:52 PM
D
same problem here
I am trying to locate where the flasher unit goes so i can replace it on my wife's car. She needs to have the hazzard lights working before she can get a new inspection sticker
It's already expired so i need an answer ASAP thanks
Old 05-09-06, 06:24 PM
D
Lightbulb
try under the dash right near the steering column, if it isnt there look on or around your fuse panel, if not there then it's probably way up under your dash and you'll have to take the dash piece off under the steering column to get to it.
Old 05-09-06, 06:26 PM
D
Lightbulb
that is probably where your flasher is(thats where mine was) you have to take that piece of dash off that under the steering column and way up in there somewhere it should be, but it might be somewhere else buti doubt it.
Old 05-10-06, 05:13 PM
W
The shrouding on the column splits leaving the steering wheel in place.............two torx head bolts hold the multi function switch to the column........two plugs and you got it licked
Old 02-19-07, 11:13 AM
Replacing the Multi-function switch fixed the hazard flashers in the dash. Thank you for the great advice.
I am having problems with the high beams, they don't turn on, even if the light is on in the dash. Can someone help, I need to pass the inspection ?
Old 02-19-07, 07:25 PM
W
The multi function is new.............so never overlook the obvious..........check the bulbs
Old 02-20-07, 07:05 AM
95 Grand Marquis
I have a 95 Crown Victoria, that I drive everyday, so I took out the bulbs from that one, and still nothing, the driving lights work , but the high beams don't ?
