Can you bend nylon fuel line permanently?
Old 05-02-06, 11:54 PM
D
Cool Can you bend nylon fuel line permanently?
I had to cut my fuel line to replace filter and bought a [B]Dorman Quick-connect Nylon Extension Kit and the line will crease if I use it as is because of the bend I need to make replacing a 45 or 60 degree elbow.
Does anyone know if I can insert heavy wire into the tubing while I heat it in water and then cool it to reshape it? I saw one report of someone heating it with a blow dryer to bend it but I need to make a substantial arc.
Trying to prevent the need to remove gas tank and replace entire line with expensive factory line.
Old 05-05-06, 07:43 PM
Z
Im not sure about the nylon, but you could try using generic metal fuel line you can buy at murrays or autozone ($2-5), put a line nut on your existing line, flare it, and use a union fitting to attach the 2 together. line and fittings will cost you around five to ten bucks.
Old 05-05-06, 08:33 PM
LouBazooka's Avatar
I agree with zzz why mess with nylon when you can use metal lines , don't take any chances with your fuel system.
Old 05-15-06, 12:29 AM
D
thanks for the input guys
thanks for taking the time to give input on my dilemma, to both of you. I fixed the problem by trading the car in on a new kia spectra and am so happy with it.
Old 01-27-14, 04:10 AM
Yes, You can Bend Nylon Fuel line permanently
It is easy to bend Nylon tube permanently and can be used safely.
You can use following method;
- Insert a spring inside the Nylon Tube.
- Take a soft metal pipe or rod (copper or aluminum can be used) and bend it to
the shape you want.
- Now, tie up your Nylon Fuel Pipe to this metal fixer.
- Give hot boiling water bath to this whole assembly.
- Remove it after 5-10 min and quench immediately in water preferably cold.
- Done.
