How to remove, re-seal and replace tail light on 2000 Dodge Neon?
Old 05-15-06, 09:57 AM
I've had a leaky trunk in my Dodge Neon for a while now. I read that the problem was improperly sealed tail lights and the solution is to re-seal them to stop the leaking. How can I do this? I purchased the silicon but am not sure how to do this correctly.
Thanks!
Old 05-15-06, 12:19 PM
LouBazooka's Avatar
Thanks!
Leaky trunk ? you mean water comes in when raining or in a car wash ? check your weather stripping on trunk for cracks or missing areas, is trunk lid bent or corroded ?
Old 05-15-06, 12:43 PM
Well, the water comes in through the tail light during the drainage process (during a rain), fills up the spare tire well, then when I brake the overflow sloshes under the back seat into the rear floorboards. I was told to reseal the tail lights to remedy the problem. Apparently it's a common problem with Dodge Neon owners. However, the forum didn't explain how to actually reseal the tail lights.
Old 05-15-06, 04:03 PM
LouBazooka's Avatar
To the best of my knowledge tail lights don't need to be sealed, they should have a perfect fit on the body housing of the car, if you want I guess you could seal the edges with silicon like you said but not a good idea IMO, never heard of it before
Old 05-16-06, 02:03 AM
tip
Get in the trunk with a flashlight have your helper outside with a garden hose water down the areas you can watch were it comes in and go from there.(make sure he lets you out)
Old 05-16-06, 08:27 AM
Thank you for your advice, I got it taken care of. Thank you again!
