89 cavalier rad fan
Old 05-21-06, 06:01 AM
89 cavalier rad fan
I have an 89 cavalier& the rad fan will not come on . I jumped out the sensors & still wont come on .Also checked for voltage to fan no voltage, Im stumped! Any suggestions? Thank u!
Old 05-22-06, 04:27 AM
lexmarks567's Avatar
did you check the fuse that controls the radiator fan.
Old 05-22-06, 05:39 AM
the_tow_guy's Avatar
And the relay.
Old 05-22-06, 02:39 PM
Angry Re 89 cavalier rad fan
Yes we checked the fuse under the dash&it was good.
Old 05-22-06, 02:42 PM
Angry re 89 cav. rad fan
Originally Posted by the_tow_guy
And the relay.
Cant find the relay, do u know the location of it?
Old 05-22-06, 04:14 PM
DaVeBoy's Avatar
They come on from water temperature, obviously. So, wherever the unit is that senses the temp and has electrical wires could be a place to start, to see if there is juice there.
Beyond that, due to wiring harness and wires that fork off this way and that, and hard to see areas, often times, I think yoU may need a wiring diagram to help yoU learn that circuit.
Old 05-22-06, 04:22 PM
Angry 89 cav rad fan
Where would I obtain a wiring diagrahm?
Old 05-23-06, 12:55 AM
chilton,,, has been my friend with every car i have owned. im told that there are better manuals around but i have had great luck with both ive bought for my cars, also i used to own a pontiac sunfire (basicaly the same car) and found it very helpfull.
Old 05-23-06, 01:56 AM
check your local libary to see if they have a sevice manual for you car if you are not allowed to check it out than photo copy the pages that you need.
