97 Plymouth Breeze only Defrost vents work
Old 05-30-06, 06:22 AM
H
Exclamation 97 Plymouth Breeze only Defrost vents work
I have a 97 plymouth breeze, recently only the defrost vents will work. I can still get the AC and Heat to work however it only blows out of the defrost vents. I have recently changed the selector controls out thinking that might be the problem. That did not help. And with the engine being mounted sideways there is not a lot of room to trace the cables to ensure there is no vacumm line leack ect...
Thanks
Old 05-30-06, 02:45 PM
Vacuum
Probably a vacuum hose has fallen off somewhere. I had this with my S10 kindof. In my S10 though, there was a motor down on the floor under the dash, and the plastic had become brittle and broke, making it so it could not open up the flap to change the air flow direction. See if you can find out where the flaps are and look for the servo motors.
