Miata rattle
Old 05-31-06, 07:43 AM
jlhofman
Angry Miata rattle
1993 when cold has a rattle in the dash/front console area for only 3-4 minutes until it is warmed. Under hood seems tight.
Any clues?
Thanks...
Old 05-31-06, 07:55 AM
have the exhuast system checked for any loose heat shields that may be vibrating or causing a rattle. if your sure its coming from the dash the odometer/ speedometer can sometimes make some noise.
Old 05-31-06, 06:16 PM
jlhofman
Smile Miata rattle...
Thanks.
Nothing appears loose when cold....
Again, thanks.
Old 05-31-06, 06:20 PM
Does it do this when in gear? or just at idle? Does it speed up or stop when you rev the engine? Do you know what a noisy lifter sounds like?
good luck
Old 05-31-06, 10:03 PM
jlhofman
Unhappy Miata rattle
The rattle is at idle and when in gear. It increases with with increased RPMs.
I'm not sure that I know what a lifter noise sounds like. Is that like a tappet tapping?
This sounds rather tinny. However, the heat shields are solidly
anchored.
Thanks for your questions......
Old 05-31-06, 10:04 PM
jlhofman
The rattle is at idle and when in gear. It increases with increased RPMs.
anchored.
