Emission test Failed - 91 Accord EX
Old 06-03-06, 05:23 PM
lttlbrch
Having trouble getting my 91 Accord to past emission test.
I had gotten a oil changed pryer to the test being done.
My first test failed with following results:
Drive Test
HC ppm - Limit 64 - Reading 2164 - Fail
CO% - Limit 0.35 - Reading 1.62 - Fail
NO ppm - Limit 727 - Reading 276 - PASS
Curb Idle Test
HC ppm - Limit 200 - Reading 155 - PASS
CO% - Limit 1.00 - Reading 0.03 - PASS
Changed Spark plugs and cleaned throtle body and retarted timing a bit. Also put in higher octane gas.Got the following results:
Drive Test
HC ppm - Limit 64 - Reading 118 - Fail
CO% - Limit 0.35 - Reading 1.61 - Fail
NO ppm - Limit 727 - Reading 501 - PASS
Curb Idle Test
HC ppm - Limit 200 - Reading 73 - PASS
CO% - Limit 1.00 - Reading 0.01 - PASS
Not sure where to go from here. Do I replace the Oxygen sensor or do I replace the catalytic converter or do I need to do both or is there something else I can do to get this car to pass.
Thanks to all that reply.
Old 06-03-06, 10:46 PM
LouBazooka's Avatar
Drive Test
Curb Idle Test
Drive Test
Curb Idle Test
Before you go to next step replace pcv valve and air filter element, keep using premium gas for at least 2 more tanks, why retard timing ? ( sorry not an expert here ) .
Some engines benefit from a good run on the freeway at least 30 minutes at 55 mph or above, carbon deposits get cleaned out the exhaust system.
Old 06-04-06, 12:53 AM
Yeah, I am also curious about the retard on the timing. The air filter should probably be replaced. If the oxygen sensor is more than a few years old, you may want to change it.
Old 06-04-06, 05:34 PM
lttlbrch
Retarding the timming will burn more fuel witch inturn will lowers the emissions. I removed the air filter before getting the second test done. So there was no restricion of air going in.
Got advice by a friend who is a mechanic and he said to dive the car till there is very little gas left and then put $5. of high grade gas and 8litres of Methyl hydrate and then go and get the Emission test done. Will be trying this out in the moring will post the outcome when I get them.
