no fuel pressure
Old 06-03-06, 07:44 PM
T
no fuel pressure
my 02 avalanche needs to crank over to build up fuel pressure to start I tested the pressure and it dropped right away I then replaced the pump but that did not seem to help any suggestion what to check next?
Old 06-03-06, 08:01 PM
C
I'd check the fuel pressure regulator, you can pull off the vacuum line and see if it's wet. It's supposed to be rated to 60-65 psi but if there's a leak in the diaphragm it won't maintain the pressure in the system.
Christopher
Old 06-04-06, 06:53 AM
B
Ditto what Christopher said.
It should eventually start though, even with a leaking regulator. (on that particular fuel control anyway)
Old 06-04-06, 07:43 AM
N
no fuel
Did you change the fuel filter too?
Old 06-04-06, 11:38 AM
C
That should have come with the new fuel pump, it's all one assembly.
Christopher
