2004 Durango Ac compressor cut off and on
Old 06-04-06, 06:26 PM
pgtek's Avatar
Received 1 Vote on 1 Post
Hi Guys
I've been going to dealer since 2 years about my ac problem
The ac compressor engage and disengage all the time
and some time it's ok
they said there no problem when they check it.
I'm not stupid i had other truck and car with ac and had no problem.
last time they replace a valve and instal a cow with a fan in it and refill the freon
it's does the same thing
when you place on recycle or not the compressor lock and turns for about 3 seconds then unlocks and lock and unlock all the time and sometime it ok
what could it be??????????
Old 06-04-06, 08:10 PM
littleworker's Avatar
With the ac on tap the sensor with a solid object thats on the compressor....it should kick on for a second....or for a while....if thats the case...you just need a new sensor....they are not expensive and are easily replaced.
Old 06-04-06, 09:10 PM
B
does it still cool sounds like it has a leak that needs to be found and repaired usually when it cycles on and off quickly it is due to low freon.
Old 06-05-06, 02:18 AM
Z
it could be low freon or the pressure sensor. i would recommend going in to a shop and have them read your pressures with a manifold gauge set.
Old 06-05-06, 12:13 PM
pgtek's Avatar
They found the problem
Hi Guys
Well finally they found the problem
It seam the gas evaporates somewhere
There looking what the cause
Old 06-05-06, 05:30 PM
Z
you can get a can of flourecent dye at the store, glasses, and light for like 20 bucks. Then look for anything glowing. I did it last year on my car.
~Bill
