90 GMC Safari Low oil pressure readings
Old 06-07-06, 08:25 AM
Good Day,
I have a 1990 GMC safari. 4.3 ltr fuel injection, automatic.
My problem is that the oil pressure guage reads low oil pressure 90% of the time. When I start the vehicle the guage goes to 3/4 of maximum for a couple seconds then back down to 1/8 It remains at 1/8 for the duration, accelerate, normal speed, always at 1/8. About once a week when I start the vehicle it goes to 3/4 at start, then works as it "should" fluctuation to 3/4when accelerating or staying at 1/2 when at normal speed.
The vehicle runs fine, no noises, oil level is ok, no oil leaks. When I changed the pcv valve three months ago the oil pressure guage started working well for a week then went back to its low 1/8 above zero state. At last oil change I used (forgot the name) the stuff you put in the oil, run it then drain it, in theory it gets the extra gunk out of the engine, no effect on low oil pressure reading. The air intake had a lot of gunk in it so I used carb cleaner to clean it, no effect.
The motor was replaced with a rebuilt one five years ago. I am wondering how to tell if the guage has failed, or an oil sending switch, or if it indeed has low oil pressure and how to correct or tell.
Your advise is greately appreciated.
Bill
Old 06-07-06, 05:10 PM
Pendragon's Avatar
Sounds like a sending unit (or the wiring to it).
A good shop will have a real oil pressure gauge they can hook up as well.
Sending units are typically not an expensive part, the last one I bought was less than $10.
Old 06-07-06, 10:02 PM
Repace oil sending switch unit as thay fail alot on GMS.
