Window off track
Old 06-08-06, 04:14 AM
F
Window off track
I have a '99 Chrysler Concorde LXI with power windows. The driver's door window seems to have come off track. Is anyone familiar here?
Is this something easy to adjust, is it difficult to get into the door to do so? Any comments appreciated.
Old 06-08-06, 12:44 PM
B
probably has a broken window regulator usually it just requires replacing the regulator check with the dealer for parts.
Old 06-09-06, 03:09 AM
F
Is this something easy to inspect, is it difficult to get into the door to do so? On a scale of 1-10 for a dyi repair, where does this range?
Old 06-09-06, 05:13 AM
B
having not done one on a concord cant really give you a good answer to how difficult of a job,should be a do it yourself repair if you take your time and use some caution when removing the regulator and installing you will have to support the window while it is being removed and installed a couple of pieces of duct tape over the top of the door and sticking to the glass on both sides is usually sufficient to hold the glass up while you change the regulator most cars can be changed in about 1-2 hours.
you will be able to partially see the regulator once you removed the door panel but you wont see nearly all of it but you may be able to tell whats wrong usually a cable will break or be completely off one of the pulleys.
