1990 ford tempo no spark
Old 06-08-06, 10:37 AM
F
new computer, new coil, new distributor, new control module, check all the fuses and all the fuseable link wires, plus also checked the computer relay, still not haveing no spark anyone have any ideals what to do next.
I check the voltage it was 12.5 volts. I had checked the roter button, it is turning. It has fuel, this year doesn't have a came sensor.
The car was running fine till, it quite like you just shut the key off. now nothing
Old 06-08-06, 11:54 AM
P
lots 'o stuff
that is a a long list of failed parts.
what was it doing before you had this problem?
do you have a rotor? does it turn with the engine cranking?
do you have a timing belt? how did you determine that you have no spark?
Old 06-08-06, 05:35 PM
DaVeBoy's Avatar
You have to do a volt test to the ignition side of the coil to see if you are getting approx. 12 volts to the coil. If you aren't, I guess you have a lot of tracing to do... and probably a wiring schematic would be in order.
Old 06-08-06, 07:11 PM
I
Only other thing is something ignition related. Try switching ignition...Is your battery/starter ok??
