Nissan Sentra 2000
Old 06-08-06, 05:46 PM
R
Nissan Sentra 2000
Hello Everyone,
I was looking to see if anyone could help me out with this. I have a Nissan Sentra 2000, 4 cylinders, 1.8 engine. 4 Oxygen sensors have been replaced, and the OBDII scanner shows code 171 and "fuel system open". The vehicle starts but does not stay running unless pressing the accelerator. Appreciate any suggestions. Thanks.
Old 06-08-06, 07:26 PM
I
Check for vacuum leaks...
check timing and idle.
check plugs
reset codes by taking off neg. batt. terminal and holding brake down for 1 min.
Old 06-08-06, 07:49 PM
LouBazooka's Avatar
check plugs
As far as I know OBDII systems can't be reset disconnecting battery.
Check for some kind of idling sensor ( ? )
Old 06-09-06, 03:37 AM
New guy's Avatar
Disconnect Mass Air Flow sensor and see if it's idling.
