02 impala squealing and noisy brakes after change
Old 06-09-06, 06:56 PM
I have recently changed the brakes on my car by myself. it was a reltivly easy process I have done many times before on pre 2000 chev models. Hoever my newer car an 02 impala I notice that my fronts squeal sometimes. And about a month later I found that my back dics were rady to change. Though I do not get a sqeal out of them it seems that after about 10-15 min of constant driving at any speed one of the rear tires start to produce a howling noise is there something I missed to cause these symptoms???
Old 06-10-06, 05:07 AM
I am suspicious you used aftermarket brake pads. Brake squeal is an undesirable side effect of this.
Old 06-10-06, 04:41 PM
DaVeBoy's Avatar
You may want to feel the metal of the wheel after driving to see if one of the rears is getting hot due to bad wheel bearing (s).
