1993 Corsica Over Heating
Old 06-11-06, 02:20 AM
9
My 93 Corsica is still overheating. 3.1L engine/auto/air 4 door sedan. The radiator was blocked up so it was replaced with a new after market radiator. In the process I lost all my freon and had to have the A/C recharged. It will idle without overheating until you turn the a/c on. ? The thermostat is opening and there is good pressure in the hose. The belt was replaced 6 months ago and so was the coolant. I caught most of the coolant while changing the radiator but had to make make fluid level with a little over a gallon of water. The fan is functioning and there are no leaks. Help!
Old 06-11-06, 03:21 AM
lexmarks567's Avatar
Is the water pump working?
Old 06-11-06, 06:36 AM
W
I'd be betting on a thermostat...........NOBODY likes to go fishing for a 3.1 T/stat trying to get that funky looking neck out from behind the exhaust crossover pipe
Old 06-11-06, 06:50 AM
9
water pump
Hey Lexmark. The water is not leaking or making noise. When you squeeze the upper radiator hose after the thermostat opens it seems to have good pressure. Is there some other way of checking the pump?
Old 06-11-06, 06:55 AM
9
thermostat
Wrench 47 The thermostat is opening. It was my first suspicion when the car orginally started over heating but when the engine warms up the top radiator hose fills up. At that point there was no pressure to speak of though. The radiator stayed cool as a cucumber...that's how I knew it was blocked up. There was no water going through that baby. Now the circulation seems good and like I said...it stays in normal range until you run the A/C.
Old 06-11-06, 08:04 AM
C
How high outside the normal range is it going? Most cars place the condenser out in front of the radiator so that gets the bulk of the clean, cool air. The radiator could be picking up heat from the condenser if the temperature rise is small. A lot of cars have circuits that will raise the idle speed when the A/C is turned on too. You'd have to check with a dealer to see if your car has that feature. If the temperature rise is higher, then you might want to consider having the water pump checked to see if it's got the proper flow rate.
Christopher
Old 06-11-06, 09:11 PM
Z
did you burp the cooling system after you replaced the radiator???
Old 06-14-06, 03:52 AM
crazycory22's Avatar
on the chevy 3.1 there's a lil screw somewhere on the nipple that the top radiator hose comes off of, and when filling you have to open that screw and let the air out of the system.
