Jeep does not start
Old 06-11-06, 08:27 AM
F
Jeep does not start
I have recently had a problem with my 1990 jeep 6 cylender engine with automatic transmission starting. At first i thought it was the battery but the problem persisted. When I jiggle the transmission shifter, the car starts fine. Is there a switch in the transmission that might be causing this? if so where is it located?
Thank you all.
Franco
Old 06-11-06, 08:56 AM
W
1990 eh?????..........Should be an Aisan/Borg Warner 4spd. the neutral safety switch is mounted on the right side of the trans where the gear select shaft protrudes............Be advised........Pricey part
Old 06-11-06, 01:42 PM
F
Jeep does not start
Thanks for the quick reply, what's the easiest way to get at it and every thing is pricey on these things.
Thanks
Franco
