2002 Honda Accord Air Conditioning doesnt work
Hello,
I recently bought a used 2002 Honda Accord Value Package with 30k miles on it. The A/C worked fine a couple of days ago until this morning, it stopped functioning . I would really appreciate if Anybody has any advice/tips.
Let Me figure this out.The blower works.the fuses are Ok. What does it do when you press the A/C button.If just hot air Maby its out of freon.
Check that the belt on the compressor is not slipping or broken. Also make sure the pully is turning. It may have a leak in the compressor and needs to be repaired and recharged. Good luck.
